Forcing a download dialog from the netburner
BMillikan
Post by BMillikan »
Does anyone know how to send the proper header to force a download dialog on the client so that I can send a file from the internal flash file system? Are there any examples of this?
Re: Forcing a download dialog from the netburner
Not sure what you are trying to do.
If you are trying to update code on the device from a file on the SD card then you want to look at the example:
nburn\examples\EFFS\EFFS-Appupdate
as that example does exactly that.
If what you want to do is update another netburner from a netburner that has not been done and I have no examples, but the source code for autoupdate is in the install.
Chris Ruff
Post by Chris Ruff »
Is what you are asking is:
How do I make the netburner post a web page with the "Save File" dialog from the browser?
Is that part of what you are asking?
and the other part is having the file come from a CF card on the netburner?
Are these what you are asking?
