Spell checking for Eclipse.
fanat9
Post by fanat9 »
More related to Eclipse/CDT by itself, but just in case someone need it.
Apparently, where is an error in CDT Ganymede/Mylyn configuration related to spell checking.
Next steps will fix it and enable full spelling capabilities:
Export current Eclipse settings to some file using File/Export/General/Preferences.
In text editor find and replace/add the next line:
/instance/org.eclipse.ui.editors/spellingEngine=org.eclipse.jdt.internal.ui.text.spelling.DefaultSpellingEngine
to
/instance/org.eclipse.ui.editors/spellingEngine=org.eclipse.cdt.internal.ui.text.spelling.CSpellingEngine
Import settings back using File/Import/General/Preferences.
Also, you can specify your personal dictionary file to have possibilities to add exclusion from spell checking.
Once you made it, you can add words to your dictionary using standard Ctrl+1 shortcut.
yevgenit
Re: Spell checking for Eclipse.
Post by yevgenit »
Which path/file needs to be edited?
Yevgeni Tunik
________________________
fanat9
Post by fanat9 »
yevgenit wrote:> In text editor find and replace/add the next line:
In which you exported Eclipse settings on previous step.
