From my cursory review of various doc's it all seems a bit more complicated than just hooking up say a Z80 to an SRAM. ie there are few unfamiliar signals such as /BS /TA /TIP /TS
Since the SRAM will be the only device on the external bus I think I can avoid needing to use buffers on the address/data lines.
Also if I am using the D16-23 for an external 8bit bus can I still use D0-15 as GPIO ?
FYI : The other port of the DP SRAM is connect to a Xilinx CPLD which drives about 4k of RGB Leds in a display matrix. ie I am trying to add a low res colour display to the 5270.
