java error on new PC and legacy eclipse
lslarry86
Post by lslarry86 »
I maintain a system on 5441x with NNDK2.8.7. Every few years I face reinstalling NNDK 2.8.7 on a new PC. This time the "new system" is Win11Pro running as a VMWare guest under Fedora42 host. NNDK installed ok from an old EXE, with an old serial number, but Eclipse is throwing Java exceptions. For Java on the Win11 guest OS, I went back and got jdk-11.0.28_windows-x64_bin.exe, on the theory that it was active in 2018. It is the only Java on this VM. NetBurner Eclipse tries to run with it, but after about a second it throws an exception dialog. There is no cut&paste, but a screenshot is Attached. The Java Exit Code is 13. Any ideas how I can make this work?
lslarry86
Re: java error on new PC and legacy eclipse
Post by lslarry86 »
Followup: same problem with JDK-8 32 bit, which I read was the last 32 bit java (2014). Same error, exit code 13.
lslarry86
Post by lslarry86 »
Never mind. I copied over my old c:\nburn tree and that works. Looks like there is a private java distro in C:\nburn\NBEclipse\jre that was not in the old installer. I should be ok. Thanks anyway.
Thanks for the followup, although surprised java8 32-bit did not work. If you have both 32 and 64 bit installed, it could be a path problem. But installing from our java link is the best.
Just a note for anyone using legacy tools, command line builds do not use java. We have made makefiles very easy to use. If you look at any example you will find a makefile. All you need to do is add your source files, all the other complexity is already done. At that point you can still eclipse, or any editor such as vscode.
Should using a modified makefile from one of the examples work with v2.9.5 of the tools? Because it doesn't work for me.
Not only that, but after running the makefile I went back to Eclipse to build my app and now I get error:
Build Error
Generated resource conflict
two resources of the same name:  /O2/Release/htmldata.o
generated by different tools
tool1:  GNU C++ Compiler
tool2:  GNU C++ Compiler
I then did a Clean Project and tried to rebuild and I get the same error.
I spoke too soon, the Clean Project generates the same error and does not delete the object files. Even manually deleting htmldata.o doesn't solve the problem. Still get the same error.
Does the example work from the command line using make and no changes to the makefile?
Remember to run \nburn\setenv.bat first.
On a clean win 11 build there is no issue installing and running 2.8.9 with 32-bit java 8 with eclipse or command line. Something must be going on with all the vm stuff. I'm not familiar with all those things your describing, but isn't one of the things a VM is supposed to do is run on a different machine? Can you take your old VM image and run it on the new computer?
Don't know where I got 2.8.9 from, but any 2.8.7 through 2.9.7 runs on a machine with win 11 natively installed per the above comment. Just confirming so you know its something with the setup, not the installer or tools.
Lastly, this may not be something you wish to do, but the 3.x tool chain does not need any separate java installation and is all 64-bit. However, you would need to port your app to the 3.x tools. I'm not saying do this to fix your problem, just providing complete info. I'm sure you have your existing app qualified and don't want to change. But for anything new its an option, and I wanted anyone reading this to know we moved away from having to deal with java installs
