compcode command not found
RebootExpert
Post by RebootExpert »
I am using NANO and Eclipse 3.5.0 (not command line) on Windows, and I am encountering the exact same issue described in this post: viewtopic.php?p=13875&hilit=compcode#p13875. Despite following all the suggestions in the post, I haven't been able to resolve the issue. The project built successfully for me before, but I’m not sure why it suddenly stopped working.
And then I imported the example TCP\TcpServerSimple and successfully built it with the target platform set to MODM7AE70. However, when I switch the target platform to either NANO or MOD5441X, I encounter a "compcode" error in the build console.
Invoking: GNU C/C++ Linker
Finished building: abc.elf
Invoking: GNU Objcopy
Finished building: abc.s19
Building target: abc.bin
Invoking: NB Compcode
/1.0/bin/sh: compcode: command not found
make: *** [makefile:73: abc.bin] Error 127
"make -j8 all" terminated with exit code 2. Build might be incomplete.
RebootExpert
Re: compcode command not found
I installed the latest version 3.5.3 and recreated the same TCP/TCPServerSimple example, but I'm encountering the same compcode error, albeit with a different error code: 126 that is permission denied.
I suspect that the path /cygdrive/c/nburn/pcbin/compcode might be incorrect, but I have no idea where the cygdrive comes from.
Finished building: test.elf
Finished building: test.s19
Building target: test.bin
/1.0/bin/sh: /cygdrive/c/nburn/pcbin/compcode: Permission denied
make: *** [makefile:73: test.bin] Error 126
RebootExpert
It turns out that our IT department has blocked the compcode.exe. They reached out to me for more specific details about this executable
Thank you very much for the quick follow up on that issue!
That is the utility that compresses the image and processes it for storage in the flash memory.
RebootExpert
Since the compcode.exe utility in the /nburn/pcbin directory was already removed by the IT antivirus in version 3.5.0 and 3.5.3, and I have versions 3.3.3 to 3.4.0 installed, could I simply copy the utility from the other version to avoid reinstalling 3.5.0? Or is the compcode.exe utility version-specific?
I will attempt to rebuild the project after they mark it as an exception utility
Hello. I think they should be the same.
RebootExpert
I copied it from 3.4.0 it build successfully now.
