Using TFTP
Using TFTP
I would like to add TFTP as a server to my NANO project. But the functions in tftp.cpp appear to be designed only for client use. Is there a server option available for the v2.9.5/6/7 version of the tools?
Re: Using TFTP
Server sourcing files or receiving files?
Where are the files the server is getting/sending coming from?
Programmatically generated/consumed?
To/From SDRAM?
Device Flash.
Device Flash file system
external SD Fat file system?
TFTP is a really simple protocol would not be hard to do, please be specific about the details...of what transactions you want this server to perform?
Re: Using TFTP
We only need to source/send a file. The file is installed at the factory during the manufacturing process via a different method and stored in EEPROM.
We receive a TCP command to prepare for file transfer, which causes the file to be copied to a buffer in sram. File size is around 128k.
It seems like a simple task could be created that just listened on UDP port 69, and when a WREQ command arrived, it would ack the command and call a modified version of function SendTFTP to send the file.
This is a rather convoluted process to send a file, but we need to be backward compatible with legacy processes.
Re: Using TFTP
I'll try and get this working this week...
Re: Using TFTP
Would this work for you:
TFTP_Server MyServer(port_num);
//Now add files to the server....
TFTP_Server_File(MyServer,"Filename.dat", pFileData, file_len);
TFTP_Server_File(MyServer,"Filename2.dat", pFileData2, file_len2);
etc for as many files as you want to serve.
Re: Using TFTP
Yes. We only have one file to send.
Re: Using TFTP
Done, submit a support request to get the code.
