How To: Visual Studio Code - NNDK 2.x on MacOS
John.Ohl
Post by John.Ohl »
I've been using VSCode for a while now for NetBurner development. Originally I followed the official tutorials (https://www.netburner.com/tag/visual-studio-code/) for the newer 3.x NNDK but it didn't work out of the box for one of our legacy products that uses the MOD5270.
Just in case anyone was interested in using VSCode for older devices here's an example makefile and configs that will get it up and running /w the 2.x NNDK for a MOD5270 /w the crypto libraries.
I use this on MacOS 12.5, though I don't think it would take much to get it working on Windows.
makefile
NAME = $(PROJECT)
PATH := $(NBROOT)/gcc-m68k/bin:$(PATH)
CXXSRCS = $(shell find . -type f -name '*.cpp')
CSRCS = $(shell find . -type f -name '*.c')
ifneq ($(filter debug loaddebug,$(MAKECMDGOALS)),)
	_DEBUG=1
endif
CREATEDTARGS = htmldata.cpp
EXTRACFLAGS = -Os -I"$(shell pwd)" -I"$(shell pwd)/include"
EXTRADBCFLAGS = $(EXTRACFLAGS)
EXTRACXXFLAGS = $(EXTRACFLAGS)
EXTRADBCXXFLAGS = $(EXTRADBCFLAGS)
XTRALIB := $(NBROOT)/lib/cryptolib.a $(NBROOT)/lib/StdFFile.a
DBXTRALIB := $(NBROOT)/lib/DBcryptolib.a $(NBROOT)/lib/debugLibrary.a $(NBROOT)/lib/StdFFile.a
NBCOMPCODE = $(NBROOT)/pcbin/compcode
NBINCLUDE = "$(NBROOT)/include"
OBJDIR = Release
ifneq ($(_DEBUG),)
	OBJDIR = Debug
endif
include $(NBROOT)/make/main.mak
htmldata.cpp: $(wildcard html/*.*)
	$(shell mkdir -p $(OBJDIR))
	$(NBROOT)/pcbin/comphtml html -dindex.html -ohtmldata.cpp
$(NBROOT)/lib/cryptolib.a: lib
$(NBROOT)/lib/DBcryptolib.a: dblib
$(NBROOT)/lib/debugLibrary.a: lib
$(NBROOT)/lib/StdFFile.a: lib
.PHONY: all load debug loaddebug build-release build-debug lib dblib build-system-libs build-system-dblibs clean clean-build rebuild-system clean-system
all: build-release
load: build-release
debug: build-debug
loaddebug: build-debug
build-release:
	@cp $(TARGET) $(OBJDIR)/$(notdir $(TARGET))
	@cp $(TARGETAP) $(OBJDIR)/$(notdir $(TARGETAP))
	@rm htmldata.cpp
build-debug:
	@cp $(DBTARGET) $(OBJDIR)/$(notdir $(DBTARGET))
	@cp $(DBTARGETAP) $(OBJDIR)/$(notdir $(DBTARGETAP))
	@rm htmldata.cpp
lib: build-system-libs
build-system-libs:
	$(MAKE) -C $(NBROOT)/system libs
dblib: build-system-libs build-system-dblibs
build-system-dblibs:
	$(MAKE) -C $(NBROOT)/system debuglibs
# TODO: Add support for auto-patching libdep for Windows, currently it needs to be patched manually
ifneq ($(OS),Windows_NT)
dblib: patch-libdep
endif
# Patch the libdep.mak include path to fix missing targets MOD5270.a and DBMOD5270.a, it shouldn't be indented under dblib:
patch-libdep:
	$(shell sed -i '' "s/^[[:blank:]]\(.*\)libdep\.mak$$/\\1libdep.mak/" $(NBROOT)/make/last.mak)
clean: clean-build
clean-build:
	-@rm -r Release
	-@rm -r Debug
rebuild-system: clean-system lib dblib
clean-system:
	$(MAKE) -C $(NBROOT)/system cleanall
# The NB main.mak builds the s19 files in the $(NBROOT)/bin directory and the $(NAME).map file in $(OBJDIR) by default
# We need to add the flag to specify where the mapfile is located so compcode doesn't fail
$(TARGETAP): override COMPCODEFLAGS+=-M $(OBJDIR)/$(NAME).map
$(DBTARGETAP): override COMPCODEFLAGS+=-M $(OBJDIR)/$(NAME).map
# Fix missing IP for debug loads
loaddebug: override NBLOADCODE+=-I$(TARGETIP)
.vscode/c_cpp_properties.json
    "configurations": [
            "name": "Netburner MOD5270B",
            "customConfigurationVariables": {
                "PROJECT": "ExampleProjetName",
                "PLATFORM": "MOD5270B",
                "TARGETIP": "192.168.2.2"
            "defines": [
                "MOD5270B",
                // "_DEBUG" Uncomment to let Intellisense know it should be in debug mode
            "cStandard": "c11",
            "cppStandard": "gnu++14",
            "browse": {
                "path": [
                    "${workspaceFolder}",
                    "${env:NBROOT}"
                "limitSymbolsToIncludedHeaders": false
            "includePath": [
                "${env:NBROOT}/include",
                "${env:NBROOT}/gcc-m68k/m68k-unknown-elf/include",
                "${env:NBROOT}/gcc-m68k/m68k-unknown-elf/include/c++/8.1.0",
                "${env:NBROOT}/gcc-m68k/m68k-unknown-elf/include/c++/8.1.0/m68k-unknown-elf",
                "${env:NBROOT}/gcc-m68k/m68k-unknown-elf/include/c++/8.1.0/backward",
                "${env:NBROOT}/gcc-m68k/m68k-unknown-elf/sys-include/**",
                "${env:NBROOT}/gcc-m68k/lib/gcc/m68k-unknown-elf/8.1.0/include",
                "${env:NBROOT}/gcc-m68k/lib/gcc/m68k-unknown-elf/8.1.0/include-fixed",
                "${env:NBROOT}/mod5270B/include"
            "compilerPath": "${env:NBROOT}/gcc-m68k/bin/m68k-elf-g++"
    "version": 4
.vscode/launch.json
    "version": "0.2.0",
    "configurations": [
            "name": "NetBurner Debug",
            "type": "cppdbg",
            "request": "launch",
            "program": "${workspaceFolder}/Debug/DB${input:PROJECT}.elf",
            "args": [],
            "cwd": "${workspaceFolder}",
            "externalConsole": false,
            "MIMode": "gdb",
            "miDebuggerPath": "${env:NBROOT}/gcc-m68k/bin/m68k-elf-gdb",
            "setupCommands": [
                    "description": "Enable pretty-printing for gdb",
                    "text": "-enable-pretty-printing",
                    "ignoreFailures": true
                    "text": "file '${workspaceFolder}/Debug/DB${input:PROJECT}.elf'"
                    "text": "set remotetimeout 10"
                    "text": "target remote ${input:TARGETIP}:2159"
            "preLaunchTask": "Build Debug & Load Project"
    "inputs": [
            "id": "TARGETIP",
            "type": "command",
            "command": "cpptools.activeConfigCustomVariable",
            "args": "TARGETIP"
            "id": "PROJECT",
            "type": "command",
            "args": "PROJECT"
.vscode/tasks.json
// See https://go.microsoft.com/fwlink/?LinkId=733558
// for the documentation about the tasks.json format
    "version": "2.0.0",
    "options": {
        "env": {
            "NBROOT": "${env:NBROOT}",
            "PLATFORM": "${input:PLATFORM}",
            "PROJECT": "${input:PROJECT}",
            "TARGETIP": "${input:TARGETIP}"
    "tasks": [
            "label": "Build Project",
            "type": "shell",
            "command": "make",
            "options": {
            "group": "build",
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
            "label": "Build & Load Project",
            "type": "shell",
            "command": "make load",
            "options": {
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
            "group": {
                "kind": "build",
                "isDefault": true
            "label": "Build Debug Project",
            "type": "shell",
            "command": "make debug",
            "options": {
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
            "label": "Build Debug & Load Project",
            "type": "shell",
            "command": "make loaddebug",
            "options": {
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
            "group": "build",
            "dependsOn": "Build Debug Project"
            "label": "Clean Project",
            "type": "shell",
            "command": "make clean",
            "options": {
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
            "label": "Rebuild System Libraries",
            "type": "shell",
            "command": "make rebuild-system",
            "options": {
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
            "label": "Run addr2line tool",
            "type": "shell",
            "command": "arm-eabi-addr2line -Cife obj/release/NetburnerBase.elf ${input:addr2line}",
            "options": {
            "problemMatcher": {
                "base": "$gcc",
                "fileLocation": [
                    "relative",
    "inputs": [
            "id": "addr2line",
            "type": "promptString",
            "description": "Enter the address to search"
            "id": "PLATFORM",
            "type": "command",
            "args": "PLATFORM"
            "id": "PROJECT",
            "type": "command",
            "args": "PROJECT"
            "id": "TARGETIP",
            "type": "command",
            "args": "TARGETIP"
Re: How To: Visual Studio Code - NNDK 2.x on MacOS
Thank you for posting that John! We do see a lot of people using VSCode
