Netburner MQTT PAHO Library - publish size limit
ecasey
Post by ecasey »
I am trying to add MQTT to an existing app on a MOD5282 using version 2.86. I can get it to work but the publish size is limited to 72 characters. Any more characters and it returns -1. I can't find anything in the code that would set an upper limit explicitly.
Does anyone have any suggestions to overcome this limit?
ecasey
Re: Netburner MQTT PAHO Library - publish size limit
Post by ecasey »
I figured it out. There is a parameter at line 111 of MQTTClient.h with a default set:
int MAX_MQTT_PACKET_SIZE = 100
When I changed the default to 1000, it published my 450 byte message. There doesn't seem to be a more elegant way of changing that parameter.
Hope this helps someone.
Thank you for posting the follow up. I'm sure it will.
