Bootup output
Bootup output
Using v3.3.6 with a NANO, when the NANO boots up there are two abort messages out the serial port. Is that normal, and is there a way to remove one?
Primary network interface configured for DHCP
MAC Address = 00:03:f4:0e:e9:c1
Type "A" to abort boot
Re: Bootup output
The SB800EX, NANO54415 and MOD5441x products have an 2.x compatible alternate boot monitor, and that is where the first message is coming from. The second is from the 3.x boot sequence. If you abort when the first message appears, type "setup" and select "quiet boot" the message will no longer appear.
Re: Bootup output
In the Boot section of the module's Configuration webpage I found a BootQuiet option, and that removed the second abort message.
