Creating makefiles in v3.x
Under Project Properties of Eclipse, the Builder Settings frame has a checkbox labeled "Generate Makefiles automatically", that is checked. Eclipse created two files for my project named makefile.defs and makefile.targets, but no makefile. Is that normal? All the example programs have a makefile but no .defs or .targets files.
I'm using v3.3.4.
Re: Creating makefiles in v3.x
If your going to use makefiles, don't use eclipse at all. Start with any example makefile that is close to what you want, and modify your .cpp file list. For example, the ShowInterfaces makefile is below:
# Revision: 3.3.4
NAME = ShowInterfaces
CPP_SRC += \
src/main.cpp \
src/ip_util.cpp
CREATEDTARGS += src/htmldata.cpp
CPP_SRC += src/htmldata.cpp
src/htmldata.cpp : $(wildcard html/*.*)
comphtml html -osrc/htmldata.cpp
include $(NNDK_ROOT)/make/boilerplate.mk
If you wanted to add a source file named foo.cpp:
CPP_SRC += \
src/main.cpp \
src/ip_util.cpp \
src/foo.cpp
And so on. the '\' is a line continuation so you can have each file on it's own line.
The htmldata stuff is all automatic, just leave it as is. Anything you do in your project's html folder will automatically be handled.
The boilerplate.mk has all the detailed stuff for the compiler. The objective is to make something easy to use, so you only need to worry about your CPP_SRC.
If you want to use eclipse as an editor, that is fine. But if using command like makefiles, do not have eclipse manage your project or create any makefiles. The makefile docs are in the 3.3.x tool docs in the "Command Line" section.
If you want to see things in action, open a command prompt, go to an example such as \nburn\examples\ShowInterfaces, and type "make -j". The -j tells the compiler to use multiple cores for the build.
