how to close secure websocket properly
RebootExpert
Post by RebootExpert »
I try to use the function close() to close a secure websocket and it will stop my app from working. but it runs fine with non secure websocket
printf("closing wss_fd = %d\r\n", wss_fd);
close(wss_fd);
printf("wss_fd = %d closed\r\n", wss_fd);
the second print statement never execute.
Re: how to close secure websocket properly
That should work...
What NNDK version are you running on what platform?
I'd like to try to reproduce your issue....
Platform?
NNDK version?
RebootExpert
It's 2.9.3 and mod54415. The weird thing is that sometimes it prints out and sometimes it doesn't.
Ok for close sometimes and not others, I might suspect some stack issues....
I'll see if we can recreate...
I've got a few things ahead of this on my plate, I'll see if the engineer working on TLS can take a look...
RebootExpert
I think close the ssl fd that associated with the secure websocket first solve the issue. Is there a function to get the ssl fd from a websocket fd? Like the function SSL_GetRawSocket(int sslSocketFd) return the tcp fd from a ssl fd. Right now I create a task monitor the state of all the ssl fd that associated with a websocket, but I don't want to have a task just for that.
I need something simple like this.
if( websocket is closed remotely)
	fd = GetFdFromWS(ws_fd);
	if(IsSSLfd(fd))
		close(fd);
	close(ws_fd);
WE fixed some SSL/TLS close issues in rev 2.9.5.
Could you see if the problem exists under 2.9.5?
RebootExpert
When I rebuild all system files in 2.9.5, it gives me errors.
C:\nburn\gcc-m68k\msys\1.0\bin\sh.exe: *** Couldn't reserve space for cygwin's heap, Win32 error 0
make: *** [C:\nburn/make/librules.mak:48: extraio.o] Error 1
buffers.o userparam.o ftp.o arp.o md5c.o udpsocket.o tzsetchar.o aes.o system.o
0 [main] us 0 init_cheap: VirtualAlloc pointer is null, Win32 error 487
AllocationBase 0x0, BaseAddress 0x71110000, RegionSize 0x2E0000, State 0x10000
make: *** [C:\nburn/make/librules.mak:59: ftp.od] Error 1
update
follow the post by anguel in this thread, I rebase the msys-1.0.dll to 0x30000000 solve the problem
RebootExpert
regard to the secure websocket closure, issue still present in the app build by 2.9.5
Jon
Post by Jon »
Hi RebootExpert,
It sounds like you had a working solution above, but wanted the SSL FD to close first. In this case, you can call:
int sslFd = 0;
WebSocket* ws = GetWebSocketRecord( webSocketFd );
if( ws != nullptr )
sslFd = ws->m_fd_tcp;
In this case, the TCP is actually the SSL fd, as it's assigned the return value of SSL_Connect(). You can then close this fd, and should be good to go.
Kind Regards,
Jon
