Trouble Reading GPIO Pin Value
Jcz
Post by Jcz »
I have a system using a MOD54415 where amongst other things has four rotary encoders hooked up to it.
They are connected to pins J1[5] and J1[6], J1[7] and J1[9], J1[10] and J1[13], and J2[45] and J2[47]. They were working fine but the encoders weren't super accurate, so I've been playing around with adding the low pass filter design recommend in the datasheet (part # PEC11R-4215F-N0024), but running it off of 3.3V.
After adding the filter circuits the encoders behaved much better except for the ones connected to the J2 pins and the one on J1 10 and 13. I checked the resistances on the pins and found that the ones that work read at around 1.2Mohm where the ones that didn't read at around 9-10kohm (J2 45, 46, and J1 13).
The netburner wasn't detecting any level change from the encoder connected to the two J2 pins and was only seeing a change in the pin connected to J1[10] not J1[13]. Changing the filter resistor out for a 2kohm on the pins with the lower resistance enabled the netburner to see the level change but it wasn't as accurate.
We were suspecting maybe the slew rate of the pins was too slow, I attempted changing the slew rate of the J1[13] pin via
sim1.gpio.srcr_fb2 |= 0x03;
but I may have not done that correctly as I've never messed around with changing the slew rates before and it didn't change anything.
Would there be something I could be overlooking in the code that I need to enable? I'll include the inits and the encoder logic below.
I could also very well be heading down the wrong path and these differences in resistances that I'm seeing are not the root of the issue.
#define P5A 10
#define P5B 13
//P5
J1[P5A].function(PINJ1_10_GPIO); //Channel A input
J1[P5B].function(PINJ1_13_GPIO); //Channel B input
void EncoderCheckTask(void *pd)
	int lastA1 = J1[P1A], lastA2 = J1[P2A], lastA3 = J1[P5A], lastA4 = J1[P6A];
	while(1)
		a1 = J1[P1A];
		a2 = J1[P2A];
		a3 = J1[P5A];
		a4 = J1[P6A];
		if((a1 != lastA1) && (lastA1 == 1))
			//Rotary encoder turn detected
			OSSemPost(&ENCODER_1);
		else if ((a2 != lastA2) && (lastA2 == 1))
			OSSemPost(&ENCODER_2);
		else if ((a3 != lastA3) && (lastA3 == 1))
			OSSemPost(&ENCODER_3);
		else if ((a4 != lastA4) && (lastA4 == 1))
			OSSemPost(&ENCODER_4);
		lastA1 = a1;
		lastA2 = a2;
		lastA3 = a3;
		lastA4 = a4;
void TaskEncoderP5(void *pd)
    int b;
    int counter = 0;
	while(1)
		OSSemPend(&ENCODER_3, 0);
		b = J1[P5B];
		if(b != a3)
			counter++;
			counter--;
		iprintf("%d ", counter);
I changed this around in the code for the system to not use semaphores and tasks for each encoder rather the check task just makes a function call. But functionally they operate the same. The a1-4 variables are declared globally.
Jeremy
Re: Trouble Reading GPIO Pin Value
Slew rate register is only for Output control....
Jcz
Post by Jcz »
Yup, I realize that now, brain fart.
I switched the channel A pin to go on J1[31] which had the same 1Mohm resistance that we had measured and this seems to have fixed the issue, also using 2k resistors on the LPF. I just wish I could figure out why it wasn't happy with what I was giving it.
J1-13 is the TA pin it has a 10K pull up.
J2-25 and J2-47 are *IRQ pins and have 10K pull ups.
So that is the source of the 10K impedance.
