Problem with 3.3.0 FTP Server access from web browser
jaypdx
Post by jaypdx »
I took the example from examples\EFFS\Fat\Ftp and added it to my MOD55415 application. It kind of works, but not completely. I can FTP into the board from the command line and things seem to work ok (dir, cd, get/put all work). But if I try to connect from Chrome or Edge (i.e. open ftp://192.168.1.10) I get an error like 'This server is sending data Google Chrome can't understand'.
I remember using this stuff years ago on a 2.x project and I'm pretty sure it worked ok using a browser to access the FTP. Any idea what's going on?
Re: Problem with 3.3.0 FTP Server access from web browser
I'm not sure exactly what you are using, but I tried a number of ftp clients, such as filezilla, windows command line and ws-ftp and they all work.
ftp://x.x.x.x also worked for me on firefox and edge. Chrome would not accept ftp:// anything, whether a netburner board or any other ftp site.
I would try an unmodified example that uses ftp and the file system as a check. Whatever your doing in the code might affecting the format.
jaypdx
Post by jaypdx »
Looks like the problem was some strange timestamps on my card.
Here's what I was getting if I FTP'd into the netburner from windows command prompt:
ftp> dir
200 Port Command okay.
125 Data connection already open; transfer starting.
d-rw-rw-rw-   1 none         0 Jan  0  1980 0
d-rw-rw-rw-   1 none         0 Jan  0  1980 1
d-rw-rw-rw-   1 none         0 Jan  0  1980 2
d-rw-rw-rw-   1 none         0 Jan  0  1980 3
d-rw-rw-rw-   1 none         0 Jan  0  1980 4
d-rw-rw-rw-   1 none         0 Jan  0  1980 5
d-rw-rw-rw-   1 none         0 Jan  0  1980 6
d-rw-rw-rw-   1 none         0 Jan  0  1980 7
d-rw-rw-rw-   1 none         0 Jan  0  1980 8
d-rw-rw-rw-   1 none         0 Jan  0  1980 9
d-rw-rw-rw-   1 none         0 Dec  6 12:43 System Volume Information
--rw-rw-rw-   1 none   6548149 Jan 16  2018 logfile.txt
--rw-rw-rw-   1 none     20181 Nov 19 23:06 LOGFILE.TXT
--rw-rw-rw-   1 none      1372 Dec 24 13:57 scratch
--rw-rw-rw-   1 none       716 Dec 24 13:11 config.txt
226 Closing data connection. Listing complete.
ftp: 767 bytes received in 0.08Seconds 9.71Kbytes/sec.
ftp> quit
Not sure how those strange time/datestamps got on there, but after formatting the card things are back to normal and browser access to FTP works just fine.
Likely you wrote the files before the system had gotten time...
IE NTP had not yet finished.
So time stamps were all bogus...
