MOD54415 External SD card F_ERR_NOT_FORMATTED
sulliwk06
Post by sulliwk06 »
I've been trying to to get the external (offboard) SD card working with my MOD54415 and I was having some trouble, so I've eliminated as many variables as possible and this is what I've got.
I have installed a fresh copy of the development tools 2.9.3 and I'm only using the example programs MOD5441X/EFFS-MULTIPLE-MMC and StandardStack/EFFS/EFFS-Performance. These were tested on a MOD54415 in a MOD-DEV-70 board.
The Multiple MMC example is able to read the onboard SD card just fine, but the offboard one shows up as not formatted.
***************Off board flash
FAT mount to  failed: F_ERR_NOTFORMATTED
drive change failed: F_ERR_INVALIDDRIVE
Unmounting card
*** Error in f_delvolume(): F_ERR_INVALIDDRIVE
I know the SD card is formatted because I can read it fine on my computer and also in an old MOD5282 application I had laying around.
So I loaded up the Performance example to try to format the card anyways and the format call returns "invalid sector".
NNDK Revision: Rel_2.9.3
Mounting drive 0 in MULTI_MMC mode
FAT mount to SD/MMC failed: F_ERR_NOTFORMATTED
Retrieving external flash usage...
*** Error in f_getfreepace(): F_ERR_INVALIDDRIVE
B - Create a single file
C - Create files test (1000 files)
D - Delete all files
L - List files
F - Format drive (takes a long time)
R - Read speed (1000000 bytes)
S - Drive statistics
W - Write speed (1000000 bytes)
f
Formatting SD/MMC card
*** Error in f_format(): F_ERR_INVALIDSECTOR
Am I missing something obvious here?
Re: MOD54415 External SD card F_ERR_NOT_FORMATTED
What is the version number of your Mod-dev70
Have you installed JP4?
sulliwk06
Post by sulliwk06 »
MOD-DEV-70 Rev 1.93
JP4 is installed (what does that do?)
It connects the Write protect sense to the device...
So still no change in behavior???
sulliwk06
Post by sulliwk06 »
No, JP4 was already installed the whole time. I just ran a test without JP4 and it then said it was write protected. Then I put JP4 back on and got the not formatted error again.
Configured IP = 0.0.0.0
Configured Mask = 0.0.0.0
MAC Address= 00:03:f4:07:d8:dd
Application: EFFS FAT Tests
SD/MMC Card is write-protected. Disable write protection then press <Enter>
<Installed JP4>
L - List files
f
L - List files
Thanks for that additional information. Can you please let me know the revision number on your MOD54415?
sulliwk06
Post by sulliwk06 »
MOD54415 Rev 1.9
I'm unable to reproduce the issue. Can you try the attached image file and let me know if you see any errors.
EFFS-MultipleMMC_APP.zip
(158.25 KiB) Downloaded 787 times
That app should be run with just the sd card plugged into the mod-dev-70, no card in the 54415 microSD slot
sulliwk06
Post by sulliwk06 »
Running the program you provided seems to have the same results, so if that program worked for you then there must be something off with my hardware. I'll see if I can scrounge up a totally different dev board, processor, and SD card and try again.
===== Starting EFFS Onboard test Program =====
Trying DHCP
DHCP assigned the IP address of :192.168.1.227
Formatting drive 0...Formatting  card
Unmounting card
Program complete. Reset to repeat
