PK70 Erase Flash
dboles
PK70 Erase Flash
Post by dboles »
I'm hoping someone can point me to some documentation, procedure or forum post that addresses how to securely erase the on-chip flash for the PK70 Development Kit. Thanks in advance!
Re: PK70 Erase Flash
How much of the flash do you need to erase? You can't erase all of it, or the device will no longer function.
Can you clarify exactly what your mean by securely erase?
dboles
Post by dboles »
Basically the Application portion of the Flash, not the bootstrap portion of the firmware.
The device resides in a secure space and any device that has any Non-Volatile Memory must undergo "approved" sanitization once it leaves the space. Some vendors provided written procedures in place for this that we submit, but as an engineer, I can sign off that it was erased, but I can't find anything in the documentation that addresses how to erase any portion of the flash, just overwrite it with another application.
That can be done, but there are not any docs on how to do it that I know of. If you can open a support ticket engineering can get you what you need.
The PK70 has the following flash areas:
Boot
configuration
user param
application...
(Potentially file system) if you included one in your app...
Boot //Erase this and you have a brick
Loading an application that executes:
FlashErase( ( void * ) &UserParamBase, 8192 ); //Kills Userparam
FlashErase( ( void * ) 0xff830000, 0x3CFFF0); //Kills the entire APP image and any area set aside for file system.
Then while the unit is still running this app (its erased the flash image of itself, but its still running in RAM)
Use autoupdate to load some trivial app so you don't have to use the boot monitor to recover.
(The standardstack\web\simple html would be a good candidate for this).
