mod54415 rev2.1 config record corrupt
andyroll
Post by andyroll »
Hello, mod54415 rev2.1 after "Power_ON" send message "config record corrupt",
"Boot record invalid"
Command "Setup" send Config data, but after change (IP_addr for example) ,
I can't save whis change
How I can repair Boot record ? Can I make this manually ?
(by manual memory correct )
Re: mod54415 rev2.1 config record corrupt
I would first try the jumper recovery procedure, which will load a default configuration copy of the config record. Then change the parameters you need and save. The application config record is in parallel flash, and it can be corrupted by an errant application. But the jumper recovery was designed to recover from that.
