NNDK 2.8.7 & MODM7AE70
saram1
Post by saram1 »
I am a new user of NetBurner. I am tring to get started working with the Development Kit, MODM7AE70.
I am trying to ran one of your examples but with out luck.
I always get to the stage I need to set the platform options but when I click the search button for getting it automatically I got an empty ack.
I understand it relate to IP address, so I used the IPSetup and try to fill IP manually. Again in the "Select a Unit" I got an empy box.
Why I can't go on? Why the NBEclips can't see my Development Kit, MODM7AE70?, What am I missing?
saram.
Re: NNDK 2.8.7 & MODM7AE70
The ARM products require the 3.0 tools. Here is the breakdown of the tools versions as of April 2019:
2.7.x: IPv4 only, works with all products except ARM, Eclipse requires java 32-bit.
2.8.x: IPv4/IPv6 dual stack, works with all products except ARM, Eclipse requires java 32-bit.
3.0.x: IPv4/IPv6 dual stack, works with ARM and 5441x products (MOD54415, MOD54417, SB800EX, NANO54415), Eclipse requires java 64-bit
