Setting "Configured IP"
On a NANO54415 I notice that on boot-up that "Configured IP" is set to a previous static IP used some time ago. Normally it comes up as 0.0.0.0. It's not obvious to me where in my code I might be setting it. It's definitely not intentional.
Does setting the IP Address and Netmask in an InterfaceBlock cause those values to be saved in flash?
I'm using v2.8.5.
void ChangeRuntimeIPSettings( InterfaceBlock *ib_, IPADDR &IpAddr, IPADDR &IpMask, IPADDR &IpGate, IPADDR &IpDNS )
  #ifdef _DEBUG_NETWORK
  iprintf("Old Settings:\r\n");
  iprintf("   IP:    "); ShowIP(ib->netIP); 	iprintf("\r\n");
  iprintf("   Mask:  "); ShowIP(ib->netIpMask); iprintf("\r\n");
  iprintf("   Gway:  "); ShowIP(ib->netIpGate); iprintf("\r\n");
  iprintf("   DNS:   "); ShowIP(ib->netDNS); 	iprintf("\r\n");
  iprintf("-------------------------------\r\n");
  #endif
  ib_->netIP		= IpAddr;
  ib_->netIpMask	= IpMask;
  ib_->netIpGate	= IpGate;
  ib_->netDNS		= IpDNS;
  iprintf("New Settings:\r\n");
  #endif
Re: Setting "Configured IP"
No, as you can see in the function name that only changes the runtime settings. To save it in flash you would need to modify a configuration record structure, then specifically write that structure to flash.
Boot into the alt montior ie hit 'A" to abort
and type setup....
What do you see there?
Also run IPSETUP whet do you see there?
