Nesting Critical Sections
Is it a problem to nest critical sections?
void func1()
    OSCriticalSectionObj protectthis( bus_access );
    // do stuff
    func2();
void func2()
    // More stuff
    func3();
void func3()
    // even more.
Re: Nesting Critical Sections
Yes what you have described will work just fine.
The one area that will get you in trouble is if you have two differnt critical sections....
OSCriticalSectionObj protectthis( list_access);
In this case its REALLY important that you always enter in the same order....
IE if in one code path you have
And in a differnt code path (in a differnt task)
You will eventually end up hung in a dead lock....
So if ANY path can acquire two or more critical resources then any other path that acquires these resources MUST DO THEM IN THE SAME ORDER.
USER_ENTER_CRITICAL also counts as a critical resource.....for this ordering rule.
That's good information. Thank you.
