SNMP question
SNMP question
I copied this function from an example in one of the NB manuals, and it works, but I have 2 questions. First, shouldn't pInfo be static since it's on the stack? Second, if I put a printf statement inside the if statement, before the return, why does the program crash almost every time it boots.
const SysInfo * GetSysInfo()
	SysInfo *pInfo = ( SysInfo * ) GetUserParameters();
	if ( pInfo->valid == 0x12345678 )
		return pInfo;
       // initialize structure.
Re: SNMP question
Its part of the SNMP static initalization.
So it happens before the system is setup, hence a printf here will cause the system to try and print to i/o that is not setup.
Its getting the record directly out of flash, and its returning a pointer to that memory block.
Its not static because the pointer is just used to hold the return value, of a pointer, not hold the content of the structure....
If something else changes the record in flash then next time this info is gotten it will get the fresh flash contents...
Re: SNMP question
Ah, that explains it. Thank you.
As an aside, in another thread I mentioned that when I turn on stack checking I get a warning in my MIB file telling me to reduce local variables. It turns out that the warning was caused by calling function SetSysInfo.
void SetSysInfo( SysInfo si )
  si.valid = 0x12345678;  // You may want something more meaningful or robust.
  SaveUserParameters( &si, sizeof( SysInfo ) );
It's because the SysInfo structure is being passed on the stack. I overloaded the function with one that accepts a pointer to the structure and the warning went away.
