Single TCP Socket Connection
tigger
Post by tigger »
Hello all,
I'm using Netburner MOD5270.
Here's the sample code that found from C:\nburn
    @file       main.cpp
    @brief      NetBurner Simple TCP/IP Server Example
    This program will create a TCP server task, which listens on port 23 by
    default. To test the application you can use Telnet. For example, from a
    windows commpan prompt, type `telent <ip address of netburner>`.
    This example uses a simple read() function to receive data from a TCP
    client.
#include "predef.h"
#include <tcp.h>
#include <init.h>
const char *AppName = "Simple TCP Server Example";
#define TCP_LISTEN_PORT	23   // Telent port number
#define RX_BUFSIZE (4096)
//----- Global Vars -----
char RXBuffer[RX_BUFSIZE];
 Convert IP address to a string
void IPtoString(IPADDR  ia, char *s)
    PBYTE ipb= (PBYTE)&ia;
    siprintf(s, "%d.%d.%d.%d",(int)ipb[0],(int)ipb[1],(int)ipb[2],(int)ipb[3]);
// Allocate task stack for UDP listen task
DWORD   TcpServerTaskStack[USER_TASK_STK_SIZE];
 TCP Server Task
void TcpServerTask(void * pd)
    int ListenPort = (int) pd;
    // Set up the listening TCP socket
    int fdListen = listen(INADDR_ANY, ListenPort, 5);
    if (fdListen > 0)
        IPADDR	client_addr;
        WORD	port;
        while(1)
            // The accept() function will block until a TCP client requests
            // a connection. Once a client connection is accepting, the
            // file descriptor fdnet is used to read/write to it.
            iprintf( "Wainting for connection on port %d...\n", ListenPort );
            int fdnet = accept(fdListen, &client_addr, &port, 0);
            iprintf("Connected to: ");
            ShowIP(client_addr);
            iprintf(":%d\n", port);
            writestring(fdnet, "Welcome to the NetBurner TCP Server\r\n");
            char s[20];
            IPtoString(EthernetIP, s);
            siprintf(RXBuffer, "You are connected to IP Address %s, port %d\r\n",
                     s, TCP_LISTEN_PORT);
            writestring(fdnet, RXBuffer);
            while (fdnet > 0)
                /* Loop while connection is valid. The read() function will return
                   0 or a negative number if the client closes the connection, so we
                   test the return value in the loop. Note: you can also use
                   ReadWithTimout() in place of read to enable the connection to
                   terminate after a period of inactivity.
                int n = 0;
                do
                    n = read( fdnet, RXBuffer, RX_BUFSIZE );
                    RXBuffer[n] = '\0';
                    iprintf( "Read %d bytes: %s\n", n, RXBuffer );
                while ( n > 0 );
                // Don't foreget to close !
                iprintf("Closing client connection: ");
                close(fdnet);
                fdnet = 0;
        } // while(1)
    } // while listen
 User Main
extern "C" void UserMain(void * pd)
    init();
    // Create TCP Server task
    OSTaskCreate( TcpServerTask,
                  (void  *)TCP_LISTEN_PORT,
                  &TcpServerTaskStack[USER_TASK_STK_SIZE] ,
                  TcpServerTaskStack,
                  MAIN_PRIO - 1);	// higher priority than UserMain
    while (1)
        OSTimeDly( TICKS_PER_SECOND * 5 );
I used putty to telnet in and it's all working great...
However, when I leave the current connection open and tried another connection with putty, MOD5270 sends [SYN, ACK] to client side. I was able to open more than 10 connections with no problem and I confirmed thru wireshark that MOD5270 sends [SYN, ACK] messages.
I don't want to allow any other connections. Can anyone help me with this?
Re: Single TCP Socket Connection
Uh... why? Also, when you say you opened 10 more corrections, was this 10 concurrent connections or did you close them in between?
sulliwk06
Post by sulliwk06 »
Couldn't you just close the listen fd until you are ready to allow another?
Just close the listening socket.....
Be careful because TCP does not have keep alive so you will not ever know of the one connected TCP socket is connected to a dead machine and
thus you have stopped listening because you have a connection.... only you really don't have a valid connection anymore...
To fix this issue you need to use keepalive
there is an example
nburn\examples\standardstack\tcp\tcp_simple_keepalive
tigger
Post by tigger »
Solved it. Thank you all!
