Mod5441x-FactoryApp
Mod5441x-FactoryApp
When I compile the MOD5441x Factory App example program (unchanged) I get errors about 'J2' not declared in this scope in file webfuncs.cpp.
And the compiler is right. There is no J2 declaration in any of the files for this example.
Is an include file missing?
I'm using v2.7.5.
Re: Mod5441x-FactoryApp
I changed the offending statements from 'J2' to 'Pins' and now it compiles. But if you look in Pins.h, there is this statement:
if (!defined PK70 && !defined SB70LC && !defined NANO54415 && !defined SB800EX)
Since I'm compiling for the MOD5441x, I don't understand why the above statement is 'false'.
Somehow your compiling for the wrong platform...
That would seem to be the case. But when I look at the compiler output, I see MOD5441X in the invocation strings, which would suggest it's compiling for the right module.
Looking through the source code I don't see where the module type gets set. I think the makefiles set the module type, but I don't believe Eclipse uses makefiles. So I'm at a loss as to how to correct it.
I deleted the project and recreated it and now it compiles without error. I must have selected the wrong platform when I imported it.
