Newbie: Build errors on MOD54415 Factory App
greengene
Post by greengene »
I'm getting all kinds of errors on linking. I'm just trying to build the factory app.
I just installed 2.6.7 today.
The link is complaining about files in -some directory c:\jenkins-slave\workspace\...
Description Resource Path Location Type
more undefined references to `sim2' follow MOD54415FactoryApp line 918, external location: C:\nburn\lib\MOD5441X.a(ethernet.o):c:\jenkins-slave\workspace\012.Build.Libraries\config\all\installPlatform\MOD5441X\nburn-install\MOD5441X\system\ethernet.cpp C/C++ Problem
Any ideas?
Re: Newbie: Build errors on MOD54415 Factory App
Um... WAT? Try doing a full system rebuild then a make clean... Something is really screwy there... Basically, it's getting the platform set correctly (hence the 'MOD5441X' in the path of the undefined reference), but somehow not getting the linker right(?) hence the 'undefined sim2'.
I'm really at a loss for what's going on here...
dciliske wrote:Um... WAT? Try doing a full system rebuild then a make clean... Something is really screwy there... Basically, it's getting the platform set correctly (hence the 'MOD5441X' in the path of the undefined reference), but somehow not getting the linker right(?) hence the 'undefined sim2'.
I agree with dan, do a full rebuild of the system and platform/system. From within NBEclipse... NBEclipse->Rebuild All system files. Then, Project->Clean.
The pathing you see is just leftovers from a build/test system. Path's from the build appear in prebuilt libraries. It does not affect the library in any way.
jaypdx
Post by jaypdx »
Having the same problem. Just got a new MOD54415 eval kit and installed 2.6.8 IDE today. Starting with new project (DHCP + WebServer app wizard options selected). I get all the 'c:\jekins-slave\workspace' errors when I do a Build All, and when I try Rebuild System Files I get:
'Clean and Rebuild System Files' has encountered a problem.
Libary Build Error. See build console for details
In the console I see:
[clean] Error 1 (ignored)
rm -f ./ucosmcfa.od ./software_init.od ./ucosmcfc.od ./ucos.od ./ucosflags.od ./debugtrap.od ./ucosmain.od ./fileio.od ./md5c.od ./system.od ./userparam.od ./librarystubs.od ./aes.od ./itoa.od ./tzsetchar.od ./sha1.od ./main.od ./utils.od ./ip.od ./buffers.od ./arp.od ./dns.od ./udp.od ./udpsocket.od ./tftp.od ./ftp.od ./ftpd.od ./filepost.od ./StreamUpdate.od ./tcp.od ./extraio.od ./httppass.od ./http.od ./httpinternal.od ./htmldecomp.od ./htmlwritefile.od ./htmlvarplaceholder.od ./iosys.od ./multicast.od ./mailto.od ./new_ops.od ./ppp.od ./ahdlc.od ./command.od ./autoip.od ./dhcpc.od ./dhcpd.od ./dhcpd_prefix.od ./dhcpd_standard.od ./pop3.od ./random.od ./tcpupdate.od ./defappname.od ./netrx.od ./nbtime.od ./ntpclient.od ./vjhc.od ./wifisetup.od ./netinterface.od ./multiconfig.od ./taskmon.od ./smarttrap.od ./autoupdate.od ./device.od ./base64.od ./syslog.od ./qspiShared.od ./sdShared.od ./netbios.od ./SendUdpFragment.od ./convert.od ./sdio.od ./sdioBus.od ./sdioBusSpiMode.od ./netDevice.od ./atcommand.od ./wifi.od ./release_tag.od ./release_tagdata.od ./IrqStdio.od ./init.od ./initWithWeb.od ./nbfloatprint.od ./nbiprintf.od ./nbprintf.od ./nbsiprintf.od ./nbsprintf.od ./fdiprintf.od ./fdprintf.od ./websocket_server.od
rm -f C:\nburn/lib/DBNetBurner.a
make:
jaypdx
Post by jaypdx »
Just went back to 2.6.7. Still having problems. When I try to Rebuild System Files I get:
Console:
m68k-elf-gcc -m5200 -MM ucosmcfc.c ucos.c ucosflags.c debugtrap.c ucosmain.c fileio.c md5c.c system.c userparam.c librarystubs.c aes.c itoa.c tzsetchar.c main.c -I"C:\nburn/include" -I"C:\nburn/MOD5441X/include" -DMOD5441X -DMCF5441X >>NetBurnerdepend.mk
rm -f C:\nburn/lib/NetBurner.a
rm -f NetBurnerdepend.mk
make: make: make: make: make:
make:
Also, when I click Run I get:
'Launching' has encoutered a problem
An internal error occurred during: "Launching ".
java.lang.NullPointerException
This is Win7-64. My Java info is:
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_71-b14
Any ideas?
mx270a
Post by mx270a »
I got this same error today. Like you, I'm running Windows 7 x64.
Rebooted windows and everything is working fine again. :roll:
Ok, from the collection of responses here, it sounds like a it might be a pathing problem occurring.
Jay and Greenegene, have you guys got it to work or not?
