MOD54415 Watchdog timer implementation
nicobari
Post by nicobari »
I am trying to include software watchdog in my code to reset the Netburner in case I get stuck in a loop in my code. I looked up the example for the SBL2E and slightly modified it for MOD54415. My code is include below.
///included
#include "predef.h"
#include <stdlib.h>
#include <basictypes.h>
#include <ucos.h>
#include <autoupdate.h>
#include <dhcpclient.h>
#include <taskmon.h>
#include <smarttrap.h>
#include <effs_fat/fat.h>
#include <effs_fat/multi_drive_mmc_mcf.h>
#include <effs_fat/effs_utils.h>
#include <sim.h>
#include <pins.h>
#include <ucosmcfc.h>
#include <pinconstant.h>
#include <HiResTimer.h>
#include <utils.h>
#include <constants.h>
#include <cfinter.h>
#include <math.h>
#include <serial.h>
#include <dspi.h>
#include <bsp.h>
void UserMain(void * pd);
    void SetIntc(long func, int vector, int level, int prio);
const char * AppName="wdExample";
 * Interrupt occurs if watchdog is not periodically touched. In this case, a hardware reboot will occur
INTERRUPT( wdReset, 0x2700 )
    ForceReboot();
 * Task that periodically touches watchdog. If not called, an interrupt will be triggered and
 * wdReset will force reboot.
void wdTouch( void *)
    while(1)
        OSTimeDly(TICKS_PER_SECOND);
       // sim2.scm.cwsr = 0x55; /******I commented out this portion so that I actually see the netburner restart**********/
       // sim2.scm.cwsr = 0xAA;
void UserMain(void * pd) {
    #ifndef _DEBUG
    EnableSmartTraps();
    #endif
    int fd0=0;
    SerialClose(0);
    fd0=OpenSerial( 0, 115200, 1, 8, eParityNone );//
    OSSimpleTaskCreate(wdTouch,MAIN_PRIO-1);
    SetIntc((long) &wdReset,25, 6, 3 ); /**********Level 6 interrupt for source 25 of INTC0 on MOD54415*********/
    iprintf("Starting Watchdog in 5 seconds\r\n");
    OSTimeDly(5*TICKS_PER_SECOND);
    sim2.scm.cwcr = 0x819F;/******Starting Watchdog timer**********/
    int seconds = 0;
    while (1) {
        iprintf("%d\r\n",seconds++);
        OSTimeDly(20);
I ran this code but it counts the seconds fine and never restarts even though I have commented out the write of 0x55 and 0xAA to CWSR register. What I might be doing incorrectly? I will appreciate any help in this matter.
Regards,
TM
Re: MOD54415 Watchdog timer implementation
My tools install has a 54415 watchdog example in the examples folder. Do you not have that one?
nicobari
Post by nicobari »
I don't have a MOD54415 Watchdog example in my nburn folder. Is there a way you can upload it here so I can take a look at it?
TM
nicobari
Post by nicobari »
I just noticed, I have NBEclipse 2.6.4 and MOD54415 Watchdog example is included in NBEclispse 2.6.5. I don't want to install NBEclipse 2.6.5 as it is still a Beta release.
TM
rlupish
Post by rlupish »
The following snippets should work, basically what we have running.
No intc necessary - if watchdog times out, system will reset/reboot.
// Usual #includes...
void WDG_Start(void) {
// Bit #7 is Core Watchdog Enabled: 1 = Enabled 0 = Disabled
// Bit #6-#5 is Core Watchdog reset/interrupt: 10 = reset on 1st timeout
// Bits #4-0 sets core watchdog timeout period: period = 2^^n clock cycles
// Assume system clock is running at 250 MHz
// 0x1C = 2^^30 * system cycle time = about 4.3 second
sim2.scm.cwcr = (vuword) (0xC0 | 0x1E);
* Function:
* void WDG_Stop(void)
* This function disenables the watchdog timer.
* The "sim2" class is used to access the processor registers.
* Parameters: None
* Return: None
void WDG_Stop(void) {
sim2.scm.cwcr &= (vuword) 0xFF7F;
* Function:
* int16u WDG_Is_Enabled (void)
* This function reports whether the hardware watchdog timer was
* enabled or not.
* Parameters: None
* Return:
* 1 = HW WDG is active
* 0 = HW WDG is diabled
int WDG_Is_Enabled (void) {
if (sim2.scm.cwcr & 0x80)
return 1;
return 0;
* Function:
* void ServiceWatchdog(void)
* The following function is a basic watchdog servicing routine
* to refresh the watchdog counter.
* This routine can be called inside longer wait loops to prevent the
* watchdog timer from resetting the processor.
* This routine is specific to the MOD5441X!
* Parameters: None
* Return: None
void ServiceWatchdog(void) {
sim2.scm.cwsr = (vubyte) 0x55;
sim2.scm.cwsr = (vubyte) 0xAA;
return;
watchdog_service_function = ServiceWatchdog; // This is necessary
WDG_Stop(); // Disable
WDG_Start(); // Enable
while (1)
ServiceWatchdog();
OSTimeDly(<Some Number of Ticks);
潬
nicobari
Post by nicobari »
Thanks for the help.
Regard,
TM
