NNDK Release 2.6.2 Beta for Windows and OSX
NNDK 2.6.2 beta release is now out and available for download on the NetBurner tools download page. Please report any issues in this thread or directly to support by submitting a new ticket at http://support.netburner.com.
# RELEASE 2.6.2 (April 2013)
## New in this version
* Ethernet
	* Added callback for custom ethernet handlers with RX of ethernet frames
* Examples
	* Examples for StandardStack platforms moved to StandardStack directory hierarchy
	* Added SSH Server example
	* Added BufferedAD example to MCF54415
* NANO54415
	* Added driver for internal RTC
* MOD54415
	* Multiple CAN drivers support added
## Corrections in this version
* MOD54415
	* Fixed ExternalIRQ example
	* Fixed card detection/write protection on off-board memory card reader
* NBEclipse
	* Fixed debugging bug in which network debugger failed to disconnect from target or trigger breakpoints.
	* Fixed bug in which Rebuild Libraries failed on imported projects
	* Fixed bug in which MOD5213 failed to load an application on to the device
	* Updated version tag
* Tools
	* IPSetup/Autoupdate run on any socket. This allows multiple instances to run at once
	* IPSetup/Autoupdate bug fix that prevented find from seeing devices with multiple interfaces
Re: NNDK Release 2.6.2 Beta for Windows and OSX
Errata:
We have found that the longfilename support library for fatfile systems is not properly included in this release. If you need longfilename support, here are the required libraries, which should be placed in c:\nburn\lib. As usual, when switching, call \nburn\pcbin\shortfilename.bat to use short filename, or \nburn\pcbin\longfilename.bat to use long filenames. By default, short is enabled.
fatfile.zip
SFNFatFile.a and LFNFatFile.a
(214.23 KiB) Downloaded 381 times
sblair
Post by sblair »
BTW, the download link for v2.6.2 on the Support site is broken.
sblair wrote:BTW, the download link for v2.6.2 on the Support site is broken.
Thanks for the note, it's fixed now.
