SNMP Error on NBEclipse IDE Rel. 2.5.2
soportev2p0
Post by soportev2p0 »
Hi everyone,
I just bought a SNMP licence and I did run again the installer and it add a snmp directory under C:\nburn\examples\snmp, but when I tried to run the example on C:\nburn\examples\snmp\simplesnmp\main.cpp the NBEclipseIDE Rel. 2.5.2 throw me 8 errors like this:
Description        Resource        Path        Location        Type
undefined reference to `ASN::FixUpHeader()'        main.cpp        snmp000        line 161        C/C++ Problem
undefined reference to `ASN::FixUpHeader()'        main.cpp        snmp000        line 167        C/C++ Problem
undefined reference to `ASN::PutHeader(unsigned char)'        main.cpp        snmp000        line 156        C/C++
Problem
undefined reference to `ASN::PutOctetString(char const*)'        main.cpp        snmp000        line 159        C/C++
Problem
undefined reference to `ASN::PutOidFromString(char const*)'        main.cpp        snmp000        line
158        C/C++ Problem
undefined reference to `DumpTree(int)'        main.cpp        snmp000        line 209        C/C++ Problem
undefined reference to `SnmpTrapWithData(unsigned long, char const*, int, int, void
(*)(ASN*))'        main.cpp        snmp000        line 176        C/C++ Problem
undefined reference to `StartSnmpProcessor(int)'        main.cpp        snmp000        line 308        C/C++ Problem
There are also errors for any snmp example I tried to run.
I think it is because in the .h files there are only the function prototypes, and not the implementation itself. I wonder if I need to link or include some other things. I looked for some PDF documentation about SNMP but it seems there is not one in my 'Netburner NNDK' directory. What is wrong? Do I need to somehow re-build the SNMP libs for Windows or something?
I am using NBEclipseIDE Rel. 2.5.2 on Windows Vista and I need to build an agent-trap SNMP over Netburner SB70LC board.
Please someone help me.
Re: SNMP Error on NBEclipse IDE Rel. 2.5.2
Try rebuilding all of your libraries. First, select your project, and then click on NBEclipse->Rebuild All System Files. This will take a minute or two. After its done building, do a project clean on the example application.
If it fails after you do this, can you copy and paste the entire build log in to this post?
soportev2p0
Hello Forrest,
Thanks a lot!
It worked very well and now I have the missed libraries. Finally I was able to run a couple of examples. Although these examples are pretty basic.
I was wondering if you had some others complete references that show me how to develop an snmp agent that also sends traps on this same Netburner.
