convert string into character
for everything else
roarsinc2011
Post by roarsinc2011 »
how to convert string into character format ?
v8dave
Re: convert string into character
Post by v8dave »
Hi there,
It would help if you could explain more of what you want to do with the string?
The main reason for doing something like this is sending bytes to a serial port or other device.
An explanation would help us work out what you need.
Cheers.
Can you be more clear on what you mean by string?
A C++ string class?
A null terminated character array ie
const char * foo="This is a char array";
Not really sure what your question is?
The only thing that makes sense as a question to me is how to turn a C++ string into a series of c characters, which is what the c_str() function can help with.
  using namespace std;
  string a_cpp_string ("some string");
  a_c_char_array= new char [a_cpp_str.size()+1];
  strcpy (a_c_char_array, a_cpp_string.c_str()); //c_str returns null terminated sequence so strcpy is safe
