All:
1. what is the RECOVERY signal that seems to do nothing on the DEV schematic?
2. what/who is monitoring the current sense device on the DEV? I will check out the code if I don't get an answer here. I need to know if my new design using the SOMRT1061 needs to have the current monitoring in some manner.
3. Since the only part of USART 1 is available on the pins is UART1_CTS I am guessing that UART1 is not used at all. right?
can someone enlighten me on the above points?
SOMRT1061 two things in the hardware
- Chris Ruff
- Contact:
- Chris Ruff
- Contact:
Re: SOMRT1061 two things in the hardware
OK, I think I got it.
1.RECOVERY doesn't make it off of the SOMRT module
2.The PAC1933 is there to keep a record of embedded currents for up to 36 hours if somebody wants to read it
3.a useless signal from deep-within
cheers! SOMRT1061 embedded designers
