Dir Path errors in v3.3.6
Post by SeeCwriter »
I installed v3.3.6, enabled SSH in predef.h, and imported my NANO project from v3.3.5, which also had SSH enabled. When building my project I got an error about settings.h included in NbWolfSsh.h not found. I modified the include path in NbWolfSsh.h to add "ssh" to the settings.h path. That worked, but I got the same missing file regarding another include file that needed "ssh" added to its path. With each change I made, another missing file error occurred. I've now modified seven files and am now getting "not declared in this scope" errors. All the errors are in NB source files.
Jon
Re: Dir Path errors in v3.3.6
Post by Jon »
Hi SeeCWriter,
Can you please open a ticket in support and include the exact error messages that you're getting? I'd be more than happy to help you out.
Kind Regards,
Jon
Jon
Post by Jon »
Hi SeeCWriter,
If you can add the following include paths to your NBEclipse project, I think this will solve the problems you're experiencing. You might need to undo some of the changes you've done.
${NNDK_ROOT}/libraries/include/ssh
${NNDK_ROOT}/libraries/include/crypto
I've attached an image that explains how to add these to your proejct.
Kind Regards,
Jon
