I am trying to integrate a GSM/GPRS (SIM868) working with PPP on the MODM7AE70.
So far, I have encountered the following issues.
1. In constants.h, PPP_PRIO is set to (44); CONFIG_SERVER_PRIO is also set to (44), so the OSTaskCreatewName in PPPDial() fails with no warning. Is there a reason for setting PPP_PRIO to the same priority as CONFIG_SERVER_PRIO? I set the PPP_PRIO to (46) and at least the task starts.
2. There seems to be several "endian" issues in ahdlc.cpp. I lost track of all of them, but here are the main ones:
a) In ahdlc.cpp - ahdlc_transmit() puts the two crc bytes into the packet in the wrong order.
b) In ahdlc.cpp - ahdlc_receive() at the //Adjust section, the compare if (*pWord != 0xFF03) always fails, it works if I change it to (*pWord != 0x03FF); same issue with the next compare if (*pWord & 0x0100) it works if I change it to if (*pWord & 0x0001).
3. There may also be some "endian" issues in PPP.cpp, but I lost track of changes because the iprintf(%X) function seems to print out in the wrong order. That confused me and I made a lot of changes, which I subsequently changed back. At some point, I will have to clean up my altered PPP.cpp file and do a compare to the original.
I have gotten the PPP running but still have issues.
After sending a config packet, reading the config packet from the GMRS, and sending back an ACK, there is a read of part of a packet from the GMRS, and then the Restart_Interval expires (not matter how high it is set) and a new config packet is sent. After that, the receive packet completes, but with a new id and I get a "Got ACK For wrong seq" message.
The negotiations progress until I get an IPADDR4 from the GMRS and then the connection drops.
I suspect that there is an endian issue that I missed, but I haven't been able to debug it yet.
Any help or advise would be appreciated.
Ed
PPP with NNDK 3.0 and MODM7AE70
Re: PPP with NNDK 3.0 and MODM7AE70
This has been on my todo list for awhile...
I've not gotten to it....so no specific advice.
For endian ness, for network protocol stuff we have been using the
beuint32_t
and beuint16_t
types, they correctly convert to/from big endian as appropriate for platform, ie they work for both the 3.0 coldfire and 3.0 Arm m7.
beuint32_t
and beuint16_t
Heres ia a ahdlc modfied to use beuint types...
ahdlc.cpp- (12.3 KiB) Downloaded 440 times
Thanks, that looks promising.
Is it a problem to use priority 46 for PPP? That puts it lower than HTTP.
No that priority should be fine.
(I checked in the prio change and the ahdlc changes in to our source...)
If you could open a ticket and attach your PPP I'll try to get to this next week.
