I have try to use the MOD5270 v200 without embedded ethernet connector. In my pcb design I have many problems with electromagnetic interference (EMI). Where i can find the ethernet design guide to connect my ethernet jack in correct position?
Thank'you
Network connector specification
Re: Network connector specification
There is a brand new Ethernet layout guide available on the technical documents page under "various platforms". Here is the direct link:
http://www.netburner.com/downloads/nndk ... ign200.pdf
DBrunermer
I think this link might be broken, or the document isn't properly encoded. I keep getting errors. - Dan B.
I'm not sure if this is the same guide that was mentioned previously, but there is an Ethernet Connector guide here as well:
https://www.netburner.com/support/doc-s ... -35-3/file
(though it looks like from another post that you might have already found this...)
The latest app note is attached.
- AddEthernetRJ45Connector.pdf
- (511.39 KiB) Downloaded 967 times
