return data from a web POST request
Lachlanp
Post by Lachlanp »
I want to return data and indicate that a POST request was successful, but I am not sure how this is done with Netburner software
In the web page I have the following ajax call:
  	$.ajax({type: "POST", url: 'TIMESET', async: false, data: t, timeout: 4000,
    		success: function(data){
			alert("OK" + data);
  		error: function () {
  			alert("Error updating time");
In the Netburner I have redirected the POST function using
oldPostHandler = SetNewPostHandler( doPost );		// Redirect Web page POST handler
and then the code to respond to the POST is as follows:
int doPost( int sock, char *fname, char *pData, char *rxBuffer ){
	time_t RawTime;
	if (strcmp("/TIMESET",fname) == 0){
		RawTime = atol(pData);											// time from browser in seconds
		set_time( RawTime );											// Update the time
		sprintf(rxBuffer, "HTTP/1.1 200 OK\r\n[data]");
		return 0;
		sprintf(rxBuffer, "HTTP/1.1 400");
		return 1;
This code sets the time OK but always response with 'error'.
How can I get the code to send back either OK or error, and can i send back data as well.
I don't think i have to put the HTTP code in the rxBuffer.
I would have thought that the return code would be the correct signal but I have tried 0 and 1 as return codes and both give 'error'.
any help would be appreciated.
Lachlan
Re: return data from a web POST request
You have to return the mime type etc....
#include <http.h> //For send header
#include <fdprintf.h> //For printf out a socket or file descriptor...
SendHTMLHeader( sock ); //Send the ok header and html mime type etc....
//Now send the actual page....
fdprintf(sock,"<HTML> <BODY> %s </BODY> </HTML>",data);
Creating a significant html response this way is hard...
I usually make my html page in the usual way to display the data, then redirect the post to
it...
Using...
void RedirectResponse( int sock, PCSTR new_page );
found in http.h...
Like this:
//This sends everything needed, no need to send any header before this response.
RedirectResponse( sock, "RESPONSE.HTML" );
Lachlanp
Post by Lachlanp »
thanks. with your help I have managed to fix the problem.
I couldnt get fdprint to work but once you pointed me in the correct direction, i managed to find other code.
I tried: fdprintf(sock, "<p>%s</p>", data);
What worked for me is simply:
writestring(sock, buffer);
Ever so simple when you know how.
Thanks greatly.
Lachlan
