MOD54415 DAC example
BBAdmin
Site Admin
Post by BBAdmin »
This example demonstrates simple DAC output capability and the advanced waveform output capability. Tested with tools release 2.6.
MOD54414-DAC.zip
(3.56 KiB) Downloaded 1876 times
Lachlanp
Re: MOD54415 DAC example
Post by Lachlanp »
This example refers to a function and pin definition that does not apear in the example
J2[36].function( PINJ2_36_T0OUT );
Can anyone tell me where this function and pin definition is?
Regards
Lachlan
Um... I'm not sure I understand your question. I think you're confused by the PinIO class and the pinconstants macros. If that's the case, then take a look at 'pins.h' in the system include directory (nburn/include) and 'pinconstants.h' in the platform include directory (nburn/MOD5441X/include).
amaier17
Post by amaier17 »
Can anyone confirm that this example works? I'm not getting output on my DAC0 line for the simple ramping output.
I can follow along with your initialization sequence and it seems correct and close to what I attempted, however I haven't had any success. For the analog reference voltage I simply connected J2[2] (VCC) to J2[5].
Thanks for any help!
Andrew
Hmm... That's interesting. I just ran the example on my board and it behaves exactly as expected. Two things I'll note are:
1) The example says that DAC0 is J2[36]. This is incorrect. J2[36] is DTOUT0, the timer output. DAC0 is J2[9].
2) You should also connect VSSA_DAC_ADC to ground; J2[14] to J2[1]. This is the ground reference pin for the analog module.
Do either of these help?
amaier17
Post by amaier17 »
I actually never ran the second (timer generation) section. But I have J2[1] connected to J2[14], J2[2] -> J2[5], and my oscilloscope hooked up to J2[9] and J2[1] (gnd).
I just tried using DAC1 (and J2[13]) instead of DAC0 without success. I'm going to try one of my other boards and I'll let you know if that fixes anything.
**UPDATE
It appeared to be the board I was using. The demo works properly on another board.
Thanks for your help!
Whiteurka
Post by Whiteurka »
dciliske wrote:Hmm... That's interesting. I just ran the example on my board and it behaves exactly as expected. Two things I'll note are:
i will help i hope. it actually made my work about to be completed and hopefully if there is still an issue what you shared is something that i have to apply. i will post mine once completed and hopefully someone will help me:)
Lavern
Post by Lavern »
BBAdmin wrote:This example demonstrates simple DAC output capability and the advanced waveform output capability. Tested with tools release 2.6.
I can follow with your initialization series and it looks right and close to what I used, however I have not got any success.
Get the secockpit keywords tool http://www.myversaroadtrip.com
Did you connect the pins VDDA_DAC_ADC and VSSA_DAC_ADC (Pins J2[5] and J2[14])? The power section for the analog section is separate from that of the rest of the module. If you're just working with the carrier board you can just jumper those to Vcc and Ground.
