OMG, What is it always so hard to upgrade the NNDK?
I have just tried to upgrade to 2.7.3 BETA, from 2.6.3. I created a blank project for the MOD5282, rebuild the system files, no luck. I went down to 2.7.1, created a blank project for the MOD5282, rebuild the system files, no luck. I'm guessing that it is a PATH error, but I forget what might have to been done to get this to work.
HELP!
Here are the errors:
rm -f ./ucosmcfa.od ./software_init.od ./ucosmcfc.od ./ucos.od ./ucosflags.od ./debugtrap.od ./ucosmain.od ./fileio.od ./md5c.od ./system.od ./userparam.od ./librarystubs.od ./aes.od ./itoa.od ./tzsetchar.od ./sha1.od ./main.od ./utils.od ./ip.od ./buffers.od ./arp.od ./dns.od ./udp.od ./udpsocket.od ./tftp.od ./ftp.od ./ftpd.od ./filepost.od ./StreamUpdate.od ./tcp.od ./extraio.od ./httppass.od ./http.od ./httpinternal.od ./httpstricmp.od ./htmldecomp.od ./htmlwritefile.od ./htmlvarplaceholder.od ./iosys.od ./multicast.od ./mailto.od ./new_ops.od ./ppp.od ./ahdlc.od ./command.od ./autoip.od ./dhcpc.od ./dhcpd.od ./dhcpd_prefix.od ./dhcpd_standard.od ./pop3.od ./random.od ./tcpupdate.od ./defappname.od ./netrx.od ./nbtime.od ./ntpclient.od ./vjhc.od ./wifisetup.od ./netinterface.od ./multiconfig.od ./taskmon.od ./smarttrap.od ./autoupdate.od ./device.od ./base64.od ./syslog.od ./qspiShared.od ./sdShared.od ./netbios.od ./SendUdpFragment.od ./convert.od ./sdio.od ./sdioBus.od ./sdioBusSpiMode.od ./netDevice.od ./atcommand.od ./wifi.od ./release_tag.od ./release_tagdata.od ./IrqStdio.od ./init.od ./initWithWeb.od ./nbfloatprint.od ./nbiprintf.od ./nbprintf.od ./nbsiprintf.od ./nbsprintf.od ./fdiprintf.od ./fdprintf.od ./websocket_server.od ./websocket_handler.od
rm -f NetBurnerdepend.mk
ucos.c:2:20: error: predef.h: No such file or directory
ucosmain.c:6:20: error: predef.h: No such file or directory
ucosmain.c:8:22: error: includes.h: No such file or directory
ucosmain.c:9:21: error: cfinter.h: No such file or directory
ucosmain.c:10:23: error: constants.h: No such file or directory
ucosmain.c:11:19: error: iosys.h: No such file or directory
ucosmain.c:12:17: error: bsp.h: No such file or directory
librarystubs.c:1:20: error: predef.h: No such file or directory
librarystubs.c:2:22: error: includes.h: No such file or directory
main.c:34:20: error: predef.h: No such file or directory
m68k-elf-gcc -m5200 -MM ucosmcfc.c ucos.c ucosflags.c debugtrap.c ucosmain.c fileio.c md5c.c system.c userparam.c librarystubs.c aes.c itoa.c tzsetchar.c sha1.c main.c -I"/nburn/include" -I"/nburn/MOD5282/include" -DMOD5282 -DMCF5282 >>NetBurnerdepend.mk
m68k-elf-as -m5206e software_init.s -o software_init.o
ucosmcfc.c: In function 'TopOfStackKillfunction':
ucosmcfc.c:198: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'OSTCBInit'
rm ucosmcfa.o
HELP!
rm ucosmcfa.o
Re: OMG, What is it always so hard to upgrade the NNDK?
I've never had a problem updating as long as I renamed my previous c:\nburn directory (eg c:\nburn2p6p3), then did a clean install to c:\nburn. From the output it looks like you are in a \nburn directory. A quick test to see if it is a path related issue:
If you look in c:\nburn, do you see all the folders and files such as \nburn\include, \nburn\system, \nburn\MOD5282?
Open a command prompt window
Go to c:\nburn
Run setenv.bat so set the env vars for that session
Run "make clean" followed by "make"
What is the output
Go to c:\nburn
What is the output
Indeed, I renamed the original ./nburn directory and performed a fresh install. I also rebooted the machine. The Eclipse and Netburner components work fine and my projects compile, SO LONG as I don't attempt to Rebuild All System Files. Once I attempt this step everything goes to shit and I have to reinstall.
YES
Go to c:\nburn
What is the output
PLEASE SEE ATTACHED IMAGE
YES
Go to c:\nburn
What is the output
- CmdWindow.png (46.79 KiB) Viewed 1197460 times
Sorry Mark, I didn't fully specify the directory to run make in. It should be c:\nburn\system (not just c:\nburn).
Yup, I should have known that too! Here is the output (see attached)
- Cmd.png (104.45 KiB) Viewed 1197457 times
Ok, 2 questions:
1. Did you run \nburn\setenv.bat before you went to \nburn\system and ran make?
2. If it still says it can't find \nburn\include\predef.h, do you see predef.h there is you look with windows explorer?
Ok, my bad. Re-ran the setenv.bat then dug into /system and ran the make clean and make, it look like it completed successfully. No I can properly compile again in Eclipse.
Question - Why doesn't the Rebuild All System Files work correctly under Eclipse.
- Cmd.png (107.14 KiB) Viewed 1197448 times
I think this test shows it is an issue with the env vars. When you set them in a command prompt window, they are only valid for that command prompt window. So when eclipse runs they must not be the same. I would compare what you see in setenv.bat to what your windows environment vars are set to, then make them match. On my win 7 machine when I type "environment variables" in the windows start menu search programs box, it pops up a link to set the system environment variables.
What about Windows 10 though?
Experts are showing how these testosterone boosters work right now.
Arydigital
Badnaam full Episodes here: https://www.arydigital.tv/videos/category/badnaam/
