Has anyone ever used a (queued) SPI port as a PWM/DAC?
for everything else
A thought occurred to me this afternoon: Given the right data to send, it should be possible to use an SPI module for PWM output, and using a low pass filter a crude DAC. Has anyone here ever done something as foolhardy as this?
Also, it seems to me that the QSPI on the V2 core Coldfires is perfect for testing this theory, as with the right commands should loop forever..
I think I have a project for this weekend.
Re: Has anyone ever used a (queued) SPI port as a PWM/DAC?
Well, that was easy... It's not quite 100% accurate as a PWM output, but it's fairly close.
#include <predef.h>
#include <constants.h>
#include <ucos.h>
#include <system.h>
#include <init.h>
#include <sim.h>
#include <pins.h>
#include <pinconstant.h>
#define PWM_DAT_LEN 16
uint32_t PWM_Dat[PWM_DAT_LEN] __attribute__(( aligned(32) )); // 256 bit data stream, aka 8-bit resolution
const char AppName[] = "SPI_PWM";
    void UserMain( void * pd );
void SetupDSPI()
    sim1.dspi3.mcr = 0x80000C01; // clear fifos, halt transfers
    sim1.dspi3.ctar[0] = 0x78000000;
    sim1.dspi3.sr = 0x9A0A0000; // clear flags
    sim1.dspi3.rser = 0x03000000; // enable TFF_RE and dma requests
    // DSPI3 pins are UART1, UART1 slewrate is bits [3:2]
    sim1.gpio.srcr_uart     &= ~0x0C;
    sim1.gpio.srcr_uart     |= 0x08;
void SetupDMA()
    volatile edma_tcdstruct &tcd = sim2.edma.tcd[45];
    sim2.edma.cr &= ~0x000300FF;
    iprintf("saddr: %p\n", PWM_Dat);
    tcd.attr = 0x0202;
    tcd.saddr = (uint32_t)PWM_Dat;
    tcd.soff = 0x0004;
    tcd.nbytes = 0x0004;
    tcd.daddr = ((uint32_t)&sim1.dspi3.pushr);
    tcd.doff = 0x0000;
    tcd.slast = -(PWM_DAT_LEN * 4); // reset to start PWM_Dat buffer
    tcd.dlast_sga = 0x00000000;
    tcd.citer = PWM_DAT_LEN;
    tcd.biter = PWM_DAT_LEN;
    tcd.csr = 0x0000;
uint16_t LeadBitLookup[16] = {
    0x0000, 0x8000, 0xC000, 0xE000,
    0xF000, 0xF800, 0xFC00, 0xFE00,
    0xFF00, 0xFF80, 0xFFC0, 0xFFE0,
    0xFFF0, 0xFFF8, 0xFFFC, 0xFFFE
void ReadyPWMDat(uint8_t val)
    uint8_t i = 0;
    while (val > 16) {
        PWM_Dat[i] = 0xFFFF;
        i++;
        val -= 16;
    PWM_Dat[i] = LeadBitLookup[val];
    i++;
    for (; i < PWM_DAT_LEN; i++) {
        PWM_Dat[i] = 0x0000;
    for (i = 0; i < PWM_DAT_LEN; i++) {
        PWM_Dat[i] |= 1 << 31;
void StartPWM(uint8_t val)
    ReadyPWMDat(val);
    sim2.edma.serq = 45;
    sim1.dspi3.mcr = 0xC0000000; // start transfers
void StopPWM()
    init();
    SetupDSPI();
    SetupDMA();
    J2[22].function(PINJ2_22_DSPI3_SOUT);
    J2[24].function(PINJ2_24_DSPI3_SCK);
    iprintf("Application: %s\r\nNNDK Revision: %s\r\n",AppName,GetReleaseTag());
    StartPWM( 0x2F );
    while(1) {
        iprintf("PWM_DAT:\n  [\n    ");
        for (int i = 0; i < PWM_DAT_LEN; i++) {
            if (i) { putchar(',');
                if ((i%4) == 0) { iprintf("\n    "); }
            iprintf(" 0x%08lX", PWM_Dat[i]);
        iprintf("\n  ]\n\n");
        OSTimeDly(TICKS_PER_SECOND);
