Using Netburner With Wireless Bridge
Posted: Thu Jul 16, 2009 11:00 am
Hi All,
I'm trying to use the Netburner board with a wireless bridge and am running into some problems. I have seen the link go up and work normally until I try to make a web connection back to the board. The wireless link stays up but the board stops responding (no response to any protocol including ping).
The board itself is running fine I have no problems using it directly over ethernet and am wondering if there is a problem with the bridge, the Netburner board, or some interactivity between the two. If you have used it with a bridge before can you tell me what model worked for you?
