NBFind & IPsetup lose a module
Posted: Mon May 19, 2008 5:49 am
I have two mod5270 and two 5234 modules on the same local (192...) net. All of their ethernet connections to the net run through a small dlink (?) hub. Each module runs unique code that actively works with several serial ports, the SD cards and the FTP and HTTP services. All modules continue to work. Except that every couple of days one of the modules (not necessarily the same one) seems to lose its ability to be found by either NBfind, or IPSetUp. Other than this, the code appears to be running fine. Connections to the "lost module" can still be made via http or ftp or ping, but Eclipse can't download new code unless the module can be found by NBfind or IPsetup. Resetting the lost module does not get it back. The only soultion seems to be cycling power on the hub. Suggestions? I have not tried a new hub or small switch, but I'm wondering if anyone has other suggestions before I do that?
