App Header Failed
App Header Failed
On a brand new MOD54415-200IR module, when I power it up the serial port spits out:
App Header Failed
No Valid app
App Header Failed
NetBurner MCF5441x SPI Boot Monitor V1.06 Feb 28 2020 18:20:21
HELP for help
Using the serial terminal MTTTY, I uploaded MOD5441x-FactoryApp_APP.s19 (from v2.9.5) and when it finished, the terminal output was:
Starting address = 40000490
S Record End detected
And then nothing. A reboot does the same thing.
Is there any way to recover this module?
Re: App Header Failed
Yes, have you tried the shorting jumper recovery procedure? https://www.netburner.com/NBDocs/Develo ... overy.html
Yes, I tried the shorting jumper. It didn't help. I have two modules in this state. Both are new. The serial output of the first one is what I put in my first post. Shorting jumper TP1 during bootup produces the same messages as above. It doesn't appear that the Alternate Boot Monitor is started.
The second module has a higher rev monitor so its output is a little different. On bootup with TP1 shorted the output is:
Boot overide Jumper Installed
    doing alternate boot
Config record corrupt
Configured IP= 0.0.0.0
Configured Mask= 255.255.255.0
MAC Address= 00:00:00:00:00:00
Welcome to the Netburner Alternate Boot Monitor Command Program
Netburner MCF5441x Alternate Image Monitor V1.11 July 17 2020 12:22:49
The other issue could be if something is interfering with the address or data bus. Are these plugged into your own h/w? If so, does any other module work in the same h/w?
The purpose of the recovery jumper is to put you in the Alternate Monitor as you have in your last post. Are you saying you cannot interact with the Alternate Monitor?
The modules are plugged into our hardware. Tens of modules are programmed in these test fixtures each week. It's only these two modules that won't program. It is rare that modules fail to program.
In one module it appears that the Alternate Monitor is not entered, based on the terminal output. The other module specifically says Alternate Boot Monitor. I can interact with the monitor program of both modules. It just hasn't corrected the issue so far.
Thanks for the information. The recovery jumper boots the device to the alternate monitor, which uses defaults such as DHCP. It does not support AutoIP.
Once in the alternate monitor, you would need a PC and the MOD54417 to be on a network with a DHCP server so the MOD54417 can get IP settings, then you can download your app over the network. This is important, you cannot use a direct connection from pc to MOD54417 unless you set static settings through the serial monitor.
Alternatively, you can do a serial download using the FLA command regardless of the network settings of your app.
If you have tried this and it does not work the units should be sent back for analysis and we will reset or replace.
Throughout this thread its not clear to me if a download was tried to the alt monitor with DHPC or correct statis IP settings. Can you please confirm?
Yes, we used the Alternate Boot Monitor to successfully download MOD5441x_FactoryApp_APP.s19 to both modules using the FLA command with MTTTY serial terminal. But the app never ran. The same error messages I put in my previous posts were issued.
Neither module was able to get an IP Address when plugged into our DHCP network, which is why we had to use the serial port.
It acts like something is driving the address or data bus. But if they are new units and your sure it's not your h/w, then the next step would be to RMA them. Just to confirm, these are new units out of the package?
So there is nothing we can do to correct the problem. Yes, these are brand new modules. We bought these through a distributor, Mouser. Should we go through Mouser to return them, who is fighting us tooth and nail about returning these, or send them direct to Netburner?
