MODM7AE70 - uart max baudrate
rogerio.c.labanca
Post by rogerio.c.labanca »
Hi all,
I want to know the maximum baudrate that I can configure using the MODM7AE70 serial ports.
Re: MODM7AE70 - uart max baudrate
Not as simple a question as one might like.
The baud system can divide by 8 or 16 and have a fractional component.
CPU Clock is 300MHZ.
The Perif_clock is also 300Mhz.
The baud rate setting code is in:
nburn\arch\cortex-m7\cpu\SAME70\source\serial.cpp
So I think the baud can be set as high as 37.5 M baud.
(Perif_clock / 8)
What baudrate do you want?
Better question is I want baudrate XX what is the error at that rate?
Ushavilash
Post by Ushavilash »
The maximum baud rate for the MODM7AE70 serial ports depends on specific hardware configurations and firmware settings.
Are you saying you do not know what specific baud rates you need? Or the maximum?
Hi Rogerio,
Just checking back to see if you have an idea of the baud rates you need.
