Websocket browser-to-Netburner length issue
zealott
Post by zealott »
I have a Websocket connection to a Chrome browser.
When Netburner pushes data, all god, no issues whatsoever.
However, when I try to push data from the browser to Netburner, I get an issue with messages >125 bytes (first sending is ok, the rest is garbage until I re-establish the Websocket connection. If the messages are below 126 bytes, all is good).
Output from the below is:
(if I am sending 125 bytes)
Websocket_fd read_fds received len=125 first=30
(if I am sending 126 bytes)
Websocket_fd read_fds received len=126 first=30
Websocket_fd read_fds received len=134 first=B8
Websocket_fd read_fds received len=134 first=30
void TaskWebInput(void *pd)
while(1)
fd_set read_fds;
FD_ZERO(&read_fds);
FD_SET(Websocket_fd, &read_fds);
if (select(FD_SETSIZE, &read_fds, (fd_set *)0, (fd_set *)0, TICKS_PER_SECOND * 5))
if (FD_ISSET(Websocket_fd, &read_fds))
char buffer[256];
memset(buffer, 0, sizeof(buffer));
int ret = read(Websocket_fd, buffer, sizeof(buffer));
iprintf("Websocket_fd read_fds received len=%i first=%02X\r\n", ret, buffer[0]);
On client side (triggered from a button that I push several times):
[125 bytes code]
var s="";
for(var i=0;i<12;i++)
s=s+"0123456789";
s=s+"01234";
ws.send(s);
console.log(s); // all the messages look perfectly fine in the log
[126 bytes code]
var s="";
s=s+"0123456789";
s=s+"012345"; // just one more to get 126 bytes
ws.send(s);
Any ideas?
zealott
Re: Websocket browser-to-Netburner length issue
Post by zealott »
MODM7, version 3.2.0
Remove the HTONS from line ~173 of 'nbrtos/source/websocket_server.cpp'
        m_remLen = m_remainingLen = HTONS(frame->length);
Additionally, remove the HTONL from line ~202 of the same file
        m_remLen = m_remainingLen = HTONL(frame->lengthLo);
Somewhere along the line the websocket frame structures were updated to use the BigEndian autoconversion types and the explicit byte swap calls were left in place here. As a result, the first frame of size > 125 is misread as being ~32KB long instead of whatever length it actually is. This means that the next frame received will be interpreted as more payload data from the first.
zealott
Post by zealott »
Thanks Dan, fixed the issue
I'm using v2.9.5, and it has the same lines of code that zealott was told to modify. Should I make the same modification?
The reason I ask is that we are having issues with websockets as well, but only when using an SSL connection. If the browser sends 3-messages to the module, the module won't see msg 1 until msg 3 received. It won't see msg 2 until msg 4 is received. These are short messages, less than the 125 byte that zealott was sending.
