MOD54415 - DAC Driving ADC Pin ?
lor_obzerv
Post by lor_obzerv »
Hello NB community,
I have been developing a project with the MOD54415 & the MOD-Dev-70 1.9 development board. I'm experiencing a strange phenomenon and I hope someone here will be able to explain it.
I've boiled down the problem to a use-case.
  • Init ADC Single Ended
  • Read ADC_IN5, get value X
  • POWER UP DAC
  • Read ADC_IN5, get value X+unexplained offset
The problem is that as soon as I power-up my DACs, some ADCs seem to get affected somehow.
Here is the source code to my use case :
main.cpp
Use case reproducing the problem
(3.03 KiB) Downloaded 719 times
If I let the J2[11] (ADC_IN5) pin floating, the program output is:
ADC_IN5 With DACs Powered On
(1127) 0.918989 V
ADC_IN5 With DACs Powered Off
(22) 0.017939 V
If I set the pin to about 1.1 V (with a simple divider), the program output is:
(1656) 1.350352 V
(1356) 1.105723 V
So you see there is still an offset, and it seems to be induced by the powering-up of the DACs.
Any idea what could be causing this? I have tried it on 3 different MOD54415 boards.
Thanks for your support NB community...!
