I have attached a log file. When I Attempt to start NBEclipse, I see the splash screen and then immediately fails to open and shows pop up window indicating to view the log file.
I'm at a lost. I have two computers doing the same thing. The computers are running Windows 7 and XP. I am not able to run the program at all.
The other programs that were loaded worked fine. I can see the netburner device on the network.
I am running version Rel22_rc2. as for the Java I am running Version 7 Update 5.
Thanks for any assistance in advance,
Mark
Not able to getNBEclipse to run
1340660991634.log- Log File
- (9.1 KiB) Downloaded 500 times
Re: Not able to getNBEclipse to run
If you haven't already done so check the wiki FAQ.
http://wiki.embeddedethernet.com/Suppor ... s_to_start
You mentioned your JAVA SDK version but what really matters is the JRE (aka JVM). I would think since you have a recent SDK it came with a recent JVM.
The FAQ has a link to a browser based tester, Make sure it reports 1.6 or later.
Also NNDK 2.2rc2 is kind of old (but it should still work).
The great thing about the latest NNDK 2.6.0.2 release is it's built on top of Indigo instead of Ganymede. It's still officially in beta but it looks pretty solid to me.
