I/O pin interrupt
davecove
Re: I/O pin interrupt
Post by davecove »
That is all working quite well for me.
How do I set a pin high or low? I have tried:
Pins[RED_LED_PIN].function(PINX_GPIO); // RED_LED_PIN = 3
Pins[RED_LED_PIN].drive();
Pins[RED_LED_PIN] = TRUE;
Pins[RED_LED_PIN] = 1;
Pins[RED_LED_PIN].set(true);
Dave
uh... that's strange. Setting a pin is just
Pins[YOUR_PIN_NUMBER_HERE] = 0; // make pin go low
Pins[YOUR_PIN_NUMBER_HERE] = 1; // make pin go high
You sure you're working with the correct pin number?
davecove
Post by davecove »
"You sure you're working with the correct pin number?"
Pretty sure, yeah... I am using pins 3 and 4 of J8 on a SLB2E Carrier Board and measuring the voltage against pin 11 of J8 (GND).
I am currently trying this code with all 4 possible combinations and then measuring the voltage between 3 & 11 and 4 & 11.
Pins[3].function(PINX_GPIO);
Pins[4].function(PINX_GPIO);
Pins[3] = x;
Pins[4] = y;
Pin values |  Pin Voltage (ref pin 11)
   (x,y)     |   3   |  4
  (0.0)      |  0v   | 0v
  (0,1)      |  0v   | 0.58v
  (1,0)      |  3.3v | 1.5v
  (1,1)      |  3.3v | 3.3v
Pin 3 seems fine, pin 4 seems kinda wacky...
I have tried this with a couple of different SLB2E boards and gotten the same results.
Dave
Remove JP4 and retest.
davecove
Post by davecove »
That worked... voltages on pin 4 are now the expected values for 0 and 1.
Dave
Yea, pin 4 is tied to the CTS pins of the RS-232 buffer or the USB-serial bridge if that jumper is connected. Hence where your troubles came from. A'int hardware fun?
davecove
Post by davecove »
It is fun... but only when you get great support like you guys provide.
I be like'n da NetBurner. (And I let my bosses know that too :)
Dave
