CB34-EX: Not going to bootmonitor mode
rameshsatyavaram05
Post by rameshsatyavaram05 »
I am working with CB34-EX netburner hardware. Initially i was able to go to boot monitor mode by entering 'A' character on terminal while power reset to the module. But not it is not going to boot monitor mode. Could any one help me on this?
Thank you,
Ramesh.
Chris Ruff
Re: CB34-EX: Not going to bootmonitor mode
Post by Chris Ruff »
it sounds like the time-to-boot value was shortened. Press shift'A' REAL FAST and you should be ok
rameshsatyavaram05
Thanks for your reply.
I am sending continuous 'A' characters and resetting power to netburner device. It is not going to boot monitor mode. Few days back when i used this device initially, it used to go but now it is not goinb to boot monitor mode after chaning the application.
Could you help on this?
Thank you,
Ramesh.
Sounds like the monitor is set to boot to the monitor, rather than to the application.
You can change the boot up behavior through IPSetup. Load ipsetup and select your device. Click advanced. What is your boot delay set to? Default is 2 seconds. You can also change the behavior by unselecting the checkbox "Boot to application". When not checked, your device will always boot to the monitor first.
