I am updating a system from a MOD5234 to a MODM7AE70. These boards plug into a motherboard in a larger system, all of the pins are backwards compatible (most are just GPIO) except one. Pin P2:5 is a GPIO on the MOD5234 and used as ADC VREF on the MODM7AE70. In our design this is used for a selector knob: either pulled high (3.3V) or active low (GND).
To avoid having to update the motherboard I would like to simply jump P2:5 to a different unused GPIO pin. This would mean that the ADC VREF is being changed somewhat frequently. My question is would this cause any issues like frying the ADC or is there any sort of internal pull down resistor or is this pin driven internally somehow? We are not using the ADC on this project, so I don't care if the ADC doesn't work, just don't want any damage and want to make sure the signal can pass through untouched via that pin.
As far as I can tell it should work, but I am not confident about whether this pin can be driven or affected by something internal to the MODM7AE70.
MODM7AE70 ADC VREF pin
Re: MODM7AE70 ADC VREF pin
Have not tried this.
I don't think your using the A/D so messing up Vref should be fine.
Looking at the data sheet I could find a minimum operational vvalue of 1.7V, but could not find anything on vref in the datasheet maximum table.
I think it should be fine.
I have a similar question regarding this pin. Apparently at some time I decided it was available to use as a GPIO resource. Am I correct in thinking that this is not actually true and there is no way in software to change the functionality of this pin?
...and here I was just getting used to having such a nice *clean* PCB with no green wires...
John
John
It was a GPIO on older models, looking at the chip, it says minimum operational value of 1.7V. So, using it as a GPIO (assumedly with ground being low) might cause damage to the chip. I never tried that.
A good reference for GPIO is the data sheet GPIO column. Vref is an analog input, so it is not GPIO. I've attached a screen shot of the data sheet.
- Screenshot 2024-07-24 085331.png (46.67 KiB) Viewed 101892 times
MODM7AE70 serial ports
Is it possible to use callback on several serial ports on MODM7AE70 (more that comes on Dev kit)? or is there any restriction?
Hello Ohardouin,
I am not sure how this vref ticket subject changed to MODM7AE70 serial ports. Did you change the subject when replying? It would be better to create a new entry so we do not inadvertently miss a question.
Can you please provide some more detail on your question on what you are referring to as a callback? I am not certain I understand what you mean by more than comes on the dev kit in regard to callback. Can you post what you are doing as a callback in your application with the serial ports you have currently implemented?
Callbacks... the callbacks for the MOPdM7 are slightly different than the serial callbacks for the earlier netburner devices.
#include <serinternal.h>
void MyPutChar( int num, uint8_t c )
{//Num is port number
int MyGetChar( int num )
return -1; if nothing to send.
UartData[portnum].m_pGetCharFunc =MyGettChar;
UartData[portnum].m_pPutCharFunc =MyPutChar;
The DMA serial system is much faster so on the SAME70 for maximum serial throughput its recomended that you don't use the callbacks,
but use the traditional serial interface.
